Ana içeriğe geç
Nespresso Pixie, çekilmiş kahve yerine kapsül kullanan kompakt bir kahve makinesidir. Yalnızca 25 saniyede ısınan ve bir fincan kahve demleyen tek fincanlık bir kahve makinesidir.
Where does this piece go!
Resim
I followed video on how to take apart machine to clean diffuser plate, put back together and have a black plastic piece left over. Have seen others with same problem but no-one has an answer. It would make my day to know!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The part is a component of part no. 24 in the explosion view above.
It is one of the covers of the electronic control board.
It is located at the top area of the PCB cover, just where it goes behind the thermoblock.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thank you so much. At last, the mystery is solved. Youtube had many posts asking the same question but the video creators never answered. When I rally the enthusiasm I'll take the whole thing apart again and replace the missing piece.
tarafından
hey, rate somebodies answer, please.
tarafından
Yorum Ekle
here is a parts breakdown, but I don't see anything like it.
Resim
Puan 1
1 Yorum:
It's part of number 24.
tarafından
Yorum Ekle
If you solved the mystery, would you please show where this piece goes as I have the same problem? You'll make my day too😅
Puan 0
1 Yorum:
I'm afraid I couldn't be bothered to take the Nespresso machine apart again, and all the diagrams available online weren't clear enough to show where the piece went. The machine works (twice as loud) so I think the piece stopped vibrations. It also leaks during use so is now sat in a tray to catch the water. I believe that after cleaning the parts which were cakes with coffee, I then put pressure on the O ring which many posts said you have to replace eventually. I can't be bothered to do this as once again it would require taking the whole thing apart. If you are happy to, I would suggest watching a video on replacing the rubber O ring, so you can do both repairs at the same time and be done with it.
tarafından
Yorum Ekle
It kind of separates wires of controller panel (literally touching brown wire!) from the pressure valve, Underneath the coocker (main part of the machine, heavy metal part! So at the back of it and underneath! Between clear silicone hoses and wires!) took 5 minutes to figure it out as there is no adequate help online!)
Hope it will help someone!
Puan 0
1 Yorum:
Too bad a snapshot or three weren't taken and posted to show all the diyers.
tarafından
Yorum Ekle
Yanıtını ekle
poisonivy@saintly.com sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 19
Son 30 gün: 96
Her zaman: 784
