How to replace lcd?
how to replace lcd
Bu iyi bir soru mu?
This isn't really important, but just as a point of order before we start, your phone technically has an OLED display, not an LCD. Those are two very different technologies, with the OLED being newer, with higher resolution and uses less power.
Anyway, with your phone, like several Android phones, there are two ways to do a screen replacement. The first is to remove the screen by itself. This involves taking out the battery to access the display connector, then peeling off the connector from the phone's midframe, and finally separating the OLED display from the midframe. You then have to clean off the old adhesive, replace it with a sheet of precut adhesive or use some glue such as B-7000. This video shows the steps and procedures involved.
Poco F5 Screen Replacement - YouTube
The second method is a completely different procedure in which you purchase the screen already mounted to the midframe. That alleviates the issue of separating the old screen, cleaning it and regluing it, but it means you basically have to gut the phone and move all of the interior components to the new midframe. Generally I've found that the cost of the screen+midframe assembly is only a few dollars more than the screen alone; you often make that up when you have to buy glue. This is generally the preferred and safer procedure, but which one you use is up to you. Here's a different video showing the second technique.
My apologies that neither of these is in English, but the one I found that was, wasn't of good enough quality that I could recommend it. Generally you don't need audio to follow along anyway.
Bu yanıt yardımcı oldu mu?
Hi @keygaminghs
Here's a video that shows how to replace the display.
Depending on how much you need to replace, search online for either Poco F5 display module LCD + digitizer or Poco F5 display unit complete to find suppliers that suit you best. (supplier examples only)
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 79
Her zaman: 1,395
