Ana içeriğe geç
Acer TravelMate, 1997 yılında tanıtılan, iş odaklı dizüstü bilgisayarlar serisidir. TravelMate B115 modeli 2014 yılında tanıtılmıştır.
Device ran into problem
Everytime I try to turn on my laptop, it's Acer TravelMate B117 by the way. But when ever I try to turn it on, I get a blue screening saying something like "device ran into a problem :(" and then it asks me to restart, when I click restart it just goes into alot of loading screens and goes back to the same screen that says " device ran into a problem:("
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @abdelabdramane
If Win10 is installed in the laptop try the following and check if it resolves the problem.
Turn on the laptop and when it boots into Windows, press and hold the Power button operated until the laptop shuts down.
Do this 3 times in a row i.e. Start >boot > force stop >start > boot > force stop > start > boot > force stop etc.
On the 3rd attempt it should boot int the Windows Recovery Environment menus.
If it does when in the WRE menus, select Troubleshooting > Advanced > Startup repair and follow the prompts.
If it doesn't get into the WRE menus, create a Windows recovery USB disc. You can create the recovery disc from any known working Win10 PC. All you need is a 16GB USB flashdrive and 1-2 hours of time. In the host PC go to Control panel > Recovery > Create a recovery disc and follow the prompts.
Once you have the USB recovery drive, insert it into the laptop and start the laptop and then quickly press F12 and change the boot order to USB as the 1st boot option.
The laptop should boot from the USB drive into the WRE menus. Follow the procedure as outlined above.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Abdel Abdramane sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 296
