Ana içeriğe geç
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
My keyboard backlight is having problems
I have a MacBook Air M1, and got the same problem after a battery replacement . any updates on the subject please ? how did you resolve the issue ?
Although I'm thinking that the chip that is responsible for light distribution to the backlight is been defective , or maybe the new battery is the cause.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Yorum Ekle
2 Cevap
Filtre ölçütü:
While the keyboard backlight is electrically the same across the laptops. We try to keep the models independent as the physical layout is often different.
As you didn't express how your system is failing Here's the rundown:
  • A uneven backlight is strictly an issue within the backlight light source as the illumination panel has a collection of LEDs which light up a section of the keyboard. One or more may not be lit.
  • An over-all dim keyboard is often caused by spillage into the keyboard blocking the light or the brightness setting is not set or the buck converter logic within the logic board is having problems which is often a capacitor or inductor failing.
  • If the backlight is not lighting that's often a breakdown of the electrical pathway between the logic board and the backlight panel caused by corrosion eating away the connectors and solder joints. Rarely is in the transistor logic (chip) more often it's a bad solder joint than the chip it's self.
Can you give us a better idea what you are encountering so we can help you. As you can see there are many paths and depending on your symptoms each one is a bit different.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
My backlight is no longer working on my MBA M1, where can I find the flat? Just to check is correctly connected.
Thanks
Puan 0
1 Yorum:
What do you mean "the flat"? Can you describe the problem and what you tested.
tarafından
Yorum Ekle
Yanıtını ekle
ismail Bessaad sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 77
