Ana içeriğe geç
Repair guides, service information, and troubleshooting help for Electrolux Refrigerators.
ELECTROLUX E23CS75DSS1 side-by-side ref not cooling
I have an ELECTROLUX E23CS75DSS1 side by side refrigerator. It is 18 years old and last week it stopped cooling the freezer side. I had the temp set for freezer at -18c and it was getting only to 2c to -1c. The temp for refrigerator side was set at 1c and it gets close to 2c. I cleaned condenser and compressor (it was only moderately dirty) and it didn't help. So I took the panel from inside the freezer compartment and noticed that ice formed around the evaporator. I used a hairdryer and got rid of the ice and when I turned it on again, the evaporator fan ran for a few seconds and then stopped. I unplugged the refrigerator and plugged back again, and now it shows flashing '2' on the freezer temp control and 21c on the refrigerator temp control. It is not cooling at all. Can someone help me to troubleshoot/fix this issue?
Thanks
Jay
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
8 Yorum
Hi @jay11813
Try pressing and holding the On/Off button on the control panel for 3 seconds and check if the compressor and evaporator fan turn on again. You will have to manually operate the freezer door switch (if the door is open) otherwise the evaporator fan will not operate.
tarafından
I did that Turned off first, wait for two minutes and turned it back on (with freezer door switch in closed position). When i turned it back on the display shows -21c for freezer and 1c for refrigerator for 5 seconds and then freezer display starts blinking 2. Compressor and evaporator fan did not turn on. Is there a way to bypass the controller board and test the compressor and evaporator to see if it works - to isolate the problem before replacing the controller board?
tarafından
here is the schema
https://imgur.com/a/GWhUHxL
and
https://imgur.com/a/2OPya3z
can you please guide
thanks
tarafından
ok, I found both thermistors. switched the thermistors (between refrigerator and freezer). Part numbers are 240597200 and 240597201 chatgpt says both have the same values so i interchanged. Refrigerator has been running for 7 hours and freezer is at 4c and refrigerator at 12c. will keep you posted
tarafından
@jay11813
Both compartments are not cold enough yet.
Normal operating temps the freezer should be at -18°C and the refrigerator should be approx. 3°C → 4°C
tarafından
3 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @jay11813
I don't know how to safely bypass the board when trying to power the compressor.
Is the condenser fan operating when you first connect power to the refrigerator?
If it isn't operating then there's no power coming from the board to turn it on. Looking at the schematic, the condenser fan is on the same operate circuit as the compressor, so it seems that there's a problem with the board.
If it is operating, then it could be a faulty start relay (part # 297237702
Update (09/05/25)
Hi @jay11813
I don't know. I think it must be somewhere inside the refrigerator compartment.
The parts diagram isn't that explicit. It is part # 50(241509101)
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
thanks jayeff - i am trying to find out where the controller board is
https://vimeo.com/1116339326
https://vimeo.com/1116339849?share=copy#...
can you please guide on how to locate it
tarafından
I took the backcover by the compressor but could not find a controller board there. Instead I found a bunch of cables coming from inside the refrigerator compartment - see below
https://imgur.com/a/060TpfK
Where is the controller board?
tarafından
@jay11813
Most probably behind the control panel at the top inside the refrigerator compartment
tarafından
see inside -
https://imgur.com/a/OifcoYl
i can only find the display panel controller?
tarafından
See images below -
There are 9 pins in the connector to freezer. [ 4 going to fan, 2 going to light, 2 going to defrost thermostat and heater and 1 ground ] i am not finding the thermistor ??
https://imgur.com/a/6xYRePm
can you help me locate thermistor?
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Jay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 169
