How to replace the keyboard
Now I will show you how to replace the keyboard of a Dell Inspiron laptop.
You have to prepare some equipment including a flathead screwdriver and a new keyboard.
Remember to remove all the peripherals like the AC adapter and battery from the laptop. Don't use a razor blade because it might leave some scratches on your laptop.
There are 8 steps in total:
- First, slide two battery-release latches into the unlocked position.
- Next, remove the battery from the battery base.
- Then, turn over the laptop and open it.
- After that, use a small flathead screwdriver to pry away 5 keyboard latches.
- Next, you should carefully lift the keyboard.
- Then, disconnect the keyboard cable.
- After that, remove the old keyboard.
- Finally, reverse the above steps to install the new keyboard.
I have just told you the steps to change the keyboard. If you have any questions, don't hesitate to contact us.
Bu iyi bir soru mu?
1 Yorum
I need some images and instructions on each image
Jay gizo tarafından Paylaş
