Ana içeriğe geç
2021 model, otomatik buz çözme özelliğine sahip, kapıdan su/buz pınarı veya buz yapıcı gibi yerleşik özellikleri bulunmayan bağımsız bir buzdolabı olan Frigidaire GRFS2853A* için onarım ve ek bilgiler. Bu sayfa, GRFS2853A* modeliyle eşleşen model numaraları için bilgileri kapsar.
My refrigerator continues beeping
My refrigerator is cooling properly, freezing properly, making ice properly, but the light on the door continuously flashes and it keeps beeping overtime the light comes on. And it is constant. Power cycling it doesn't work. Pulling the power for over an hour doesn't work. Holding the Crush to reset it didn't work. We are about to lose our minds. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
Hi @tonyrogers
What is the full model number of the refrigerator?
What light is flashing?
tarafından
GRFS2853AF0
It is the light in the door water/ice dispenser, under the temperature controls
tarafından
@tonyrogers
Does the water dispenser work OK?
tarafından
Everything works fine. Ice and water. Refrigerator is cooling and freezer is freezing. Just beeps and flashes the light.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @tonyrogers
I don't know.
The only thing that I can suggest is that you use the service data sheet to run the diagnostic tests and check if any errors are shown.
Maybe perform the tests for the door switches, dispenser paddle and lights first if no errors show when first entering diagnostic mode.
Hopefully it is not a control board issue.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks. I will check it out.
tarafından
Yorum Ekle
Yanıtını ekle
Tony Rogers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 203
