Ana içeriğe geç
How can I remove stuck pin?
Pin is mushroom at the top, meaning no grip, but at the bottom it has grip. I used a desoldering gun and wick still didn’t work, so I got a hot air station. Still doesn’t work. Temperature I used was 300-400°C for 15 seconds or more, but it depends. Solder is lead-free.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
Hi!
Are you able to upload some photos? This will make it easier for us to come with an answer! Thanks!
tarafından
Mybad updated picture uploaded
tarafından
@dan0, for equipment, I have an atten heating station, a Hako desoldering gun, and a soldering iron Hako 8888DX.
tarafından
Thanks! Do you have a hot air station? Would try that and then try with tweezers to get it out. Make sure you use flux first. It should come out.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I would add flux and then solder, heat, and try to pull with tweezers. Might need to increase the heat as well. Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I tried using that method to increase the temperature, but nothing happened. Is there a way I can demonstrate it to you on FaceTime?
tarafından
I’m thinking about getting a another daughter board but at the same time what if that issue come up again
tarafından
Yorum Ekle
Yanıtını ekle
randy 098 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 197
