Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Soru Tümünü görüntüle
Soru Kapandı
How to keep backlight on continuously
My problem is that it is difficult for me (67 yrs old) to see the keyboard buttons in normal light conditions on my 2.66 GHz machine.
In low light the backlight comes on and there is no problem.
Is it possible to have the backlight on at all times?
By taping off the light sensor? Where is it located?
Any other solution?
Any disadvantages?
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Keyboard stickers might solve your problem, here's some black ones: http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
Here are some white ones: http://www.amazon.com/gp/product/B0010X6...
Different Black ones with white lettering: http://www.amazon.com/ENGLISH-NON-TRANSP...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
While I've never used it, there's a software solution here. It looks like it gives you the option to leave the backlit keys on all the time. Why don't you give that a try, then let us know if it works or not.
Puan 3
4 Yorum:
nice solution +
tarafından
Looks good to me. Ralph +1
tarafından
Dear Josh,
Thank you for the tip. It works as promised. However, ik does not really help.
In broad daylight the keyboard still does not light up sufficiently. Not nearly as much as in
low light conditions. Understandable in itself. It is clear that function follows form here.
What would help is clear white lettering instead of light gray.
Thanks again.
Frits
tarafından
I think that the backlighting is probably the same luminance, but due to the bright sunlight, it probably becomes more washed out. It's the same concept of an LCD looking bright in the dark, but dim in the sunlight- even though the backlight's output has remained constant.
tarafından
Yorum Ekle
Dear Josh,
Thanks again.
Frits
Puan 0
1 Yorum:
tarafından
Yorum Ekle
Dear Guys,
Thanks for the info. I will go and try to buy a set of
these letter stickers.
There might be demand for a set of actual letterbuttons with
better contrast i.e. clear white - and transparent - lettering
on black background.
Has anybody heard of those?
Best Regards
Frits
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,147
