Ana içeriğe geç
SRS-XG300 Kablosuz Hoparlör, Sony tarafından üretilmiş bir Bluetooth hoparlördür. Bu popüler hoparlör, bağlı bir kaynak cihazdan müzik ve ses yayını yapmak için kullanılır. Hoparlör, güçlü bası ve ses netliği üretmesiyle bilinir.
AUDIO IN Jack does not recognize connection
Audio device output does not play on speaker. Bluetooth audio still works. Previously, inserting mini-stereo cable into AUDIO IN jack would prevent Bluetooth audio--this is not the case now. I have tried 3 different mini-stereo cables, audio device does output sound to earbuds through its mini stereo connection.
The Sony speaker did work two weeks ago. I went on trip and removed connections and placed speaker in its carrying case. I did not use the speaker during the trip. But it does not operate correctly upon my return home in its normal configuration.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @davejones7666
Sounds like it may be a faulty audio jack.
Some audio jacks have internal changeover contacts that when operated by the insertion of the audio cable plug, operate to disconnect the BT audio input from the speaker and connect the audio cable input to the speaker instead.
Other types of audio jacks have a single internal make contact which operates to signal the audio controller on the board to switch the audio from the BT source to the audio input source.
I don't know which type is used in the speaker but here's the ifixit Sony SRS-XG300 repair guide that will help to gain access to the inside of the speaker so that you can check if the audio jack is working OK electrically when the cable is inserted.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dave Jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 202
