Ana içeriğe geç
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Controller won’t power on or charge
To give yall some background context: I tried to solder on some brand new TMR joysticks onto my PS4 JDM-055 controller. After soldering them, it worked for a little bit. I wanted to resolder one of the sticks and I think I shorted the controller. As you assumed it no longer turns on. I don’t know what to do from here on out cause I don’t know where a certified technician in my area would be and I just want my controller to work again.
If any of yall could help that would be much appreciated
Back image
Front image
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thanks for the pictures! Soldering looks fine.. I would check the motherboard for shorts! Otherwise a replacement is required..
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Brody!
Can you share a picture with us regarding the solder work? It's possible that a trace is damaged or the motherboard had too much heat and thus something died on there.
Guide for the pictures: Adding images to an existing question - iFixit Repair Guide
Please check all the cables, solder pads and traces. If nothing is visible at first, then I would replace the motherboard OR you can check for shorts.
So, this should be the part you need: DualShock 4 Controller Motherboard (JDM-055)
Please let us know how it goes!
Main circuit board assembly for the seventh generation (JDM-055) PS4 DualShock 4 Controller. Görseli
Ürün
$34.99
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hello! Is the controller motherboard authentic?
tarafından
Hi! No, you can just swap motherboards! But you need the correct model as the original motherboard, otherwise it won't fit or can give issues.
tarafından
Yorum Ekle
Well checkout the following video it might help you in fixing the issue: https://www.youtube.com/watch?v=KC9GeYyM...
Puan 0
Yorum Ekle
Yanıtını ekle
Brody Girton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 47
