Ana içeriğe geç
2015 12" Retina MacBook Model A1534 için onarım bilgileri ve kılavuzları
LCD or GPU Issue?
I have here an A1534 1.1 GHz model that has suffered the all to common CPU failure from I guess overheating, which must be common in these fanless Macbooks.... And someone is offering me the same model (But not sure the CPU as 3 versions were made) for next to nothing price, but it comes with this apparent display issue....
Resim
Resim
Resim
I am thinking to just swap over the logic board to make a 'working' unit, but I am concerned that there maybe an irreparable GPU issue other than a faulty display..... to me it looks reminiscent of the scenario when changing the default resolution and then rebooting where these similar lines appear for a split second until the system recognizes the adjusted resolution which to me points to a GPU error as the lines remain as pictured when the system is active.
Bu iyi bir soru mu?
Puan 1
2 Yorum
it may be a gpu issue on your macbook or some componants going to the gpu got knocked off
tarafından Paylaş
Can you try it with an external monitor? That should tell you whether it's a GPU or display issue.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I'm not a MAC person, but the display appears to be functioning and the computer is having a problem. Therefore, my guess would be that the computer can't load the drivers to the GPU and isn't getting a response from the GPU. Therefore, it is likely a GPU issue. If it isn't a plug in part, the MB needs replacing.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Yeah these are nice looking MacBooks but TOTALLY useless and prone to MB Issues..... Just a nice ornament.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
livfe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 265
