Ana içeriğe geç
Samsung'un başı çeken telefonu, Galaxy S9. Mart 2018'inde piyasaya çıktı.
S9 overheating, camera not working
Hello,
I have the following issues in case anyone knows what is the problem:
  1. Front & rear camera are not working
  2. LED notification does not work
  3. Phone overheats when charging (turned off)
  4. Phone overheats more while on, and drains battery very fast
Has not been dropped or disassembled, it all started after I found it with totally empty battery despite it was on the charger.
Appreciate any ideas since I am away from home on business and I don't have access to my tools to disassemble and check source of overheating.
Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
5. Also fingerprint reader is not operational
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
@chrisp87714 based on your assessment of "Phone overheats when charging (turned off)" and "Phone overheats more while on, and drains battery very fast", the very first task I would undertake is to replace the battery. Remember heat-short circuit. Could be the battery or even your cameras. Start with the battery. If nothing else it'll be a great known-well starting point for any further troubleshooting.
Samsung Galaxy S9 Battery Replacement Sorry, but it looks like you will have to borrow some tools from somewhere. I don't think this is fixable with a software setting.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hello,
Thank you for the quick response. Yes it's most probably a hardware issue. I mentioned lack of tools because I can't open the cover and troubleshoot further to see if excess heat is coming from the battery or the mainboard. If it's any worth, the phone gets hotter at the top part above the camera and also opposite on the screen, and the sides around the buttons, less on the area of the back cover where the battery is underneath.
I also suspected the battery first but I'm thinking that it wouldn't render the camera and the notification led inoperable. Do you have in mind a case where a failing battery is causing such disruptions and overheating on the board? Or one where the camera was faulty and causing overheating?
Thank you.
tarafından
@chrisp87714 this case sounds more like the cameras shortening out the power rail. This could be through on of the cameras PMIC. Hardware wise not much going on above the cameras most of the battery PMIC's are on the opposite side of the battery.....
tarafından
Yorum Ekle
Well looking to your issue i will suggest you to do the following it might help you in fixing the issue:
  • Boot into Safe Mode
  • Boot into Recovery Mode
  • Check charging current
  • Try charging with phone fully off for 15–20 min
  • Remove SIM and SD cards
  • Software refresh
And to fix the over heading issue i will suggest you to check out the following:
https://eu.community.samsung.com/t5/othe...
Puan 0
Yorum Ekle
Yanıtını ekle
Chris P sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 224
