Giriş
Use this guide to replace the battery in your Samsung Galaxy S9.
Opening the Samsung Galaxy S9 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water protection.
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
Use the flat end of a spudger to pry up and disconnect the battery flex cable.
Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
In the following step, only apply the spudger in the areas marked in green, which is where the battery adhesive is located.
Avoid this area. There's a gap in the mid-frame right below the battery, and you can accidentally damage the display through it.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, calibrate your newly installed battery after completing this guide.
82 farklı kişi bu kılavuzu tamamladı.
22 Yorum
An exceptionally useful, and dare I add - well-written - fixit.
Merci ifixit.
Mais je n ais pas compris la deconnection du NFC, es une nappe. Je ne comprends pas.
Bonjour @Di Da, vous trouverez la partie qui parle de la démontage du coque / de la cache en plastique qui abrite l'antenne NFC et la bobine de recharge dans les étapes 9 à 11. Au fait, la cache en plastique et la nappe sont UNE pièce ensemble, on ne peut pas les séparer et dès que vous démontez la cache, la nappe va elle aussi sortir automatiquement. Elle n’est lié que par quelques contacts, vous n’avez pas besoin de déconnecter ceux-ci, ils se séparent automatiquement quand vous retirez la coque.
Wenn nach Abschluss der Reparatur der Fingerabdrucksensor nicht funktioniert muss man in den Restore Modus des Handy gehen.
Dazu das Smartphone an den Lader hängen und das Gerät ausschalten.
Dannach die Bixby + Power + Lauter Taste gedrückt halten bis das Samsung Logo erscheint.
In dem Menü den Punkt “Wipe Cache Partition” auswählen mit Lauter / Leiser und mit Power die Auswahl bestätigen.
Die Auswahl nochmal mit Yes bestätigen und warten bis das Gerät die Cache Partition gelöscht hat und das Gerät neu starten.
Dannach sollte der Fingerabdrucksensor wie gewohnt funktionieren.
Why does the guide stop? How am I supposed to use the adhesive??
