Ana içeriğe geç
Apple tasarımı M2 Pro ve M2 Max SoC'lere sahip, Ocak 2023'te piyasaya sürülen 14 inç MacBook Pro için onarım rehberleri ve söküm bilgileri.
Battery replaced not working
I have a a2779 MacBook Pro , I started getting a service battery warning last week and when I run out of power the mag safe started flashing orange and did not charge , I ordered a replacement off I fix it for the model, I fitted it this morning and when I plug the mag safe in now with the new battery installed I get no light and it does seem to charge, I tried to charge via usb c left it charging for 1 hour but nothing, can anyone help? Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
A common issue is forgetting to set the ZIF latch from the Battery board or the cable./connector is damaged. Review Step 7 ~ 9 MacBook Pro 14" (2023 Başı) Değişim Pili Onarımı here is the referee making sure the latch is not set, sliding in squarely the ribbon cable and carefully setting the latch so it's grabbed. Also check the battery side connection as well.
If the cable is damaged you'll need a replacement MacBook Pro 14" BMU Flex Cable - Apple P/N 923-08652
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Joedee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 193
