Ana içeriğe geç
No backlight on my screen
I have replaced the screen, replaced the cable to the screen, replaced the back cover for the screen. The screen still has no backlight. I can faintly see the screen if I shine some light on it. I read (in a nearly 20 year old article) that it could be the lid closed sensor, but I can't even figure out where that is. Or it could be the inverter, also can't find that, probably integrated into the motherboard these days. Any thoughts of suggestions would be appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @smeagolthe63638
Did you disconnect the battery from the motherboard before removing/replacing the display panel?
With the laptop turned on, check for voltage on the EDP connector pins 1-3 (display cable connector) and if is not there check if the FG2 fuse is blown on the board.
Here's an image from the NM-C811 motherboard schematic (if that is your board) that may help.
Resim
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Smeagol the Barbarian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 395
