Ana içeriğe geç
MacBook Pro models with a 15" display
8255 Soru Tümünü görüntüle
Can I do a one-for-one HD swap between MacBooks?
Just installed a Seagate 7200 RPM 500GB SATA-SSD hybrid drive in my 2009 Santa Rosa Macbook. Restored my data and OS (OSX Lion) from the Time Capsule, and it was a very simple and trouble free process. Thanks, iFixit!
I'm now interested in installing that drive in my wife's mid-2010 MacBook Pro completely as-is, and putting her OEM 320GB drive in the older MB. Both machines are running the same OSX version, but obviously they're quite different under the hood. Is doing a one-for-one swap with these drives as simple as plug-and-play, or is there something more I need to consider?
Thanks for the advice/tips!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You should be able to make the switch with no problems. You will need a minimum of 2 GB of RAM in the older machine.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
So the machine should boot up and, for all intents and purposes, look/act/feel in the MBP just as it did in the MB? Seems too good to be true! Will report back with the results. Thanks for the confidence!
tarafından
Yorum Ekle
Yanıtını ekle
biegerd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 643
