Ana içeriğe geç
Hem çekmece hem de kapı erişimi sunan, buz pınarı dahili, alt donduruculu bir model olan Samsung RFG298HD** buzdolabı için onarım ve ek bilgiler. Bu sayfa, RFG298HD** kalıbıyla eşleşen model numaraları için bilgileri içerir.
Auto defrost is not working
There is a 3s press switch for defrosting and it is working. But auto defrost is not working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @umchbh
Here's the RFG298HD service manual.
Go to p.51 (52 of 105 pdf) to view the self-diagnostic function during normal operation procedure and check if any error codes are shown.
Reason for trying this is because manual defrost may override any inputs that are used by the control board to determine that a defrost cycle is required. It just checks that the defrost circuit is working OK, not that a defrost cycle is required..
Which compartment is not defrosting at all or is it just not defrosting that often?
According to the RFG298HD Fast Track troubleshooting guide, the refrigerator compartment defrosts every 6-11 hours (varies according to the conditions)¹and both the refrigerator and freezer compartments defrost every 12-22 hours (varies according to the conditions)¹ - see p.3
Basically at a minimum the refrigerator compartment should be defrosted twice approx. every 24 hours and the freezer compartment only once
¹ The refrigerator uses what is known as the adaptive defrost cycle method instead of the accumulated compressor run time or the simpler fixed time period methods. With the adaptive defrost cycle method the time interval between defrost cycles is determined by how often and for how long the doors have been opened and the ambient temperature where the refrigerator is located. It is considered to be more energy efficient than the other two methods.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Umchbh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 131
