Is the 700R4 interchangeable with the Turbo 350?
Probably I will get nailed for this one, but here goes.
I have a 1986 Chevy K20 Pickup. It originally came with a Turbo-Hydramatic 350 transmission. It has a 700R4 installed now, which is shot. Will I be able to re-install a T350 with no other wiring or tubing modifications? Should I just be safe and find another 700r4 and throw it in?
Off computer topic I know, but hey do I care? There is a big knowledge base out there.
Regards,
Frank
Bu iyi bir soru mu?
9 Yorum
It's definitely a hardware problem ;-)
mayer tarafından
Got a 77 Malibu with build 305 an 350 turbo can I change trans over a a 700r ?? Or a 400turbo??
jrmauldin1991 tarafından
My advice is avoid a transmission that utilizes a Throttle Valve Cable. The plastic buckle on the end breaks, Doesn't matter what gear you're in, how fast you're going, or how far you drive with the cable not attached. You burn clutch material and it wears the gear down no matter what, more than likely resulting in a complete failure of the transmission. I've been through 2 in my 89 GMC c1500 305 slx, can I put a turbo 350 or 400 in my truck without doing anything other than the swap itself and the fluid change?
bcupgfbl2008 tarafından
I put a 350 turbo in place of a 700 with the 9 inch tailshaft.i put the 700 tailshaft on to use the electric Speedo and the shaft sticks out of the back several inches any solutions?
Smokey Summers tarafından
Stick with what u have its supposed to be a bettet tanny
terrel tarafından
4 tane daha yorum göster
