Ana içeriğe geç
Dell tarafından 2016 yılında piyasaya sürülen Precision 7510, üst düzey bir iş istasyonu dizüstü bilgisayardır. Cihazdaki hemen hemen her bileşen değiştirilebilir veya yükseltilebilir.
Backlit keyboard stoped working
Hi 👋
After changing thermal paste I was putting components together and while installing the keyboard the ribbon cable for backlight was bent a little too much accidentally, now it had a small part of it that's seem broken, even though I tried to flatten it with my fingers, since then backlit won't work anymore and I get an error concerning touchpad when running the BIOS ' diagnosis, which I believe is normal since both touchpad and keyboard are connected to the motherboard using one ribbon cable (touchpad and keyboard work fine)
the cable is the far right one is the one for backlit :
Is there a way to fix it at home ?
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @wryyy
The cable for the keyboard backlights is integrated in the keyboard and is not a removable cable that can be replaced. Besides which the cable isn't available as a spare part.
You will have to replace the keyboard to resolve the problem.
Search online for 383D7¹ to find suppliers that suit you best.
Usually the Dell part number can be found somewhere on the underside of the keyboard, if you wish to verify the keyboard part number before ordering.
Go to p.14 in the owner manual to see how to remove/replace the keyboard in the laptop.
¹ The keyboard is used in a lot of different Dell laptops. Make sure that the seller shows your model in the ad or other models that you know that the keyboard is compatible with. Here's a link that shows what I mean. (Note: the link is not an endorsement of the seller, merely an example of what to look for).
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Well I will suggest you to checkout the following video:https://www.youtube.com/watch?v=BNBxoPER...
Puan 0
Yorum Ekle
Yanıtını ekle
Wryyy!! sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 200
