Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
PS4 will not turn on.
My PS4 will not turn on. The light bar lights up for a split second then nothing, no beeps. I've replaced the power supply because I thought that was the issue. However it did not fix it, Seems pretty clean inside so I doubt its corrosion. Any ideas? I'm thinking maybe a resistor or cable connecting to the board.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
It did turn on when I first got it. But after about 5 minutes it died.
tarafından
@anti11118
But it doesn't turn on now or does it turn on and then off after 5 minutes?
You originally said that it doesn't turn on, so my answer was predicated for that problem.
If it doesn't turn on as you first said, try the answer below.
tarafından
@jayeff Doesnt turn on now. Only that first time I used it.
tarafından
@anti11118
You said "... when I first got it"., which makes it seem like it's a used console. If it is, do you know its history, was it described as fully working etc?
Try the answer below.
If the battery is the problem at least if it starts regularly (after replacing it) and then it turns off later you are a step forward into finding out what else is wrong.
At the moment you can't even get it to turn on and stay on.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @anti11118
Try a full power refresh in case the BIOS has become corrupted and is preventing a normal start.
Here’s the procedure:
a). Disconnect the power to the PSU (if connected).
b). Disassemble the console and remove the coin cell RTC battery from its holder on the motherboard. Here’s the PlayStation 4 Anakart Değişimi guide, that will help.
Unfortunately for you, the coin cell battery is on the underside of the board so the motherboard will have to be completely removed from the case. When the battery is removed use a DMM (voltmeter function) to measure the battery’s voltage. If it is <2.6V DC or if the battery is >4-5 years old, replace it. It is a CR2032 Lithium coin cell battery that is available most everywhere e.g supermarkets
c). Reinsert the coin cell battery into its holder on the motherboard (+ve on top as marked on the battery), then reverse the disassembly procedure as shown in the link above, to re-assemble the console. Reconnect the power to the PSU and check if it turns on OK.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ANTI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 70
