Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Stage Lights Again... 4 Screens
MBP 2012 13" A1278 (820-3115)
We have replaced the LCD Connector, and tested with 4 different complete known to be good display assembly's and we still have these 'stage lights', which must point to the issue being from elsewhere. @oldturkey03 any suggestions on what we can do next?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@livfe part of the backlight IC U9701 connects the cathode part of the LED strips to ground through PWM-controlled FETs. LED_RETURN_1 through LED_RETURN_6 lines are present on the LVDS connector (pin 24-Pin 29). A broken line on those will cause the anomaly we refer to as "Stagelight." :)
Here are the resistors for the LED Return lines
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
This is a contender for "Answer of the century", ,We will check the later today and I am very confident that your help will solve this one (& others hopefully!) & will get the attention it needs to help many save from buying unnecessary parts- Vielen Danke :D
tarafından
Yorum Ekle
Yanıtını ekle
livfe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 37
Son 30 gün: 37
Her zaman: 37
