Ana içeriğe geç
Bu sayfa, Dell XPS M170 MXG051 onarımı için gereken temel bilgileri gösterir. Tamir kılavuzu, kullanıcı kılavuzu ve pil çıkarma kılavuzu, sabit disk değiştirme kılavuzu ve bellek modülü kılavuzu gibi sorun giderme rehberlerinin tümü, Dell XPS M170 MXG051 cihazınızın sorunlarını çözmenize ve çalıştırmanıza yardımcı olur. Dell XPS M170 MXG051, en üst düzey bileşenlere sahip güçlü bir oyun dizüstü bilgisayarı olup en yüksek performansa ve uzun vadeli güvenilirliğe olanak tanır.
Need Drivers for Windows 7 QuickSet
Looking for Windows 7 driver for this Dell XPS M170 MXG051 laptop I need windows 7 x86 for the quick set
Thank you
Update (02/08/26)
I put in windows 7 professional x86
but get a error even after installing t dell quickset compatible with windows Vista says something about .NET Framework error and will close Quick Set
so is it the quick set of framework?
picture of website and commits
I went to the XPS M170 32bit and Windows XP is has below picture
Dell QuickSet, v.7.1.10, A38
Version7.1.10, A38
Download Type Applications
File Name R130907.EXE
File size 7.99 MB
Description
QuickSet provides the following features: POWER: Power management schemes, Battery resource information and health, Warning messages unsupported power-adapter/dock/battery scenarios are detected. DISPLAY: Display brightness, Desktop font & Internet Explorer Scaling, Display switching via Fn+F8 and presentation mode. NETWORK/CONNECTIVITY: Radio/Wireless activity control using the wireless switch (OR) the Fn+F2 hotkey depending on your system, Location Profiler (Creation and switching of profiles comprising location dependent system settings; Managing multiple connections), Internal network card activity (depending on your system), Wi-Fi Catcher(TM) Network Locator Configuration OTHER/SYSTEM SETTINGS: Volume status, Hotkey hibernate, MediaDirect (on certain systems) XPS SYSTEMS only: LED color control and Touchpad LED control (depending on your system), Advanced power schemes
View full driver details
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @tj8799
What Win7 OS is installed in the laptop - Win7 32-bit or Win7 64-bit?
The best that I can find for the model number you posted is that the CPU in the laptop does not support 64-bit OS so presumably it is Win7 32-bit
If this is the case, I'm not sure if they will install or work, even if you find them.
According to this link the drivers will only work on Win 64-bit OS and not Win 32-bit OS
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
Hi @tj8799,
windows 7 professional x86 comes in both 32-bit and 64-bit versions
To check what system is installed in your PC click Start, right-click Computer, and select Properties. The system type will be listed under the "System" section as either "32-bit Operating System" or "64-bit Operating System.
if you have 32-bit, most probably that's why it doesn't work.
tarafından Paylaş
says Vista operating systems so I ran it as Windows Vista 32 bit
tarafından Paylaş
@tj8799
The CPU in the laptop supports 32-bit only so any 64-bit programs won't work.
The QuickSet drivers from Dell I linked above are for Dell PCs that have CPUs that support 64-bit OS
tarafından Paylaş
I used the 32bit programs from Dells website and installed the windows 7 32bit
tarafından Paylaş
@tj8799
Yes but if you read the information regarding the QuickSet drivers on the page I linked it states that it only works on Windows 64-bit systems not on Windows 32-bit systems.
This is the quote from the Dell driver link above:
"Dell Update Packages (DUP) in Microsoft Windows 32bit format have been designed to run on Microsoft Windows 64bit Operating Systems. Dell Update Packages (DUP) in Microsoft Windows 64bit format will only run on Microsoft Windows 64bit Operating Systems."
You laptop CPU does NOT support Windows 64-bit systems
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
tj8799 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 243
