Ana içeriğe geç
New TMR Sticks Not Working
I am nee to soldering and know the basics. I replaced both joysticks with new TMR sticks with new Xbox joystick soldering tool. Replacement and soldering went well. But when I go to check controller with Xbox app, it connects but I can't move or use any part of controller. Any thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Hi!
Did you tried it here as well > https://hardwaretester.com/gamepad
What is working and what isn't?
tarafından
Nothing works other than the controller turning on and connecting to xbox. I'd post a video if I could
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi!
Thanks for your comment!
Perhaps traces are damaged or the board went to hot.
Please check if everything is connected as it should and also for damaged traces.
I’m afraid your motherboard did die or isn’t connected properly.
Can you check this? Thanks!
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I will have to check for this a little later, but that may be the case. I'm wondering if I may have had too much heat when desoldering the original analog sticks. Thank you
tarafından
That is possible yes... In this case you most likely want to replace the motherboard, but this isn't cheap...
tarafından
Yorum Ekle
Yanıtını ekle
kmuetz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 270
