Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
Soru Kapandı
When replacing the hard drive can I upgrade the capacity and RPM?
I have a Macbook which has a kaput hard drive, I am looking to replace it, but was wondering if i could upgrade it with a larger hard drive and/or one with more RPM?
My HDD is 2.5 inch 5400RPM
I've heard Western Digital or Seagate are the companies to go for.
Thanks,
James
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes you can, as long as the new hard drive is a standard 2.5" SATA drive then you can upgrade the capacity and the rpm. If you want large and fast then you should get a 750GB 7200 rpm hard drive. You are right, those companies are among the top brands. A good place to look for hard drive is OWC. A link to a list of compatible 7200 RPM hard drives can be found here:
http://eshop.macsales.com/shop/hard-driv...
and 5400 RPM here:
and a wide variety can be found here:
Hope this Helps
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks, I bought a 1TB hard drive with 5400 RPM.
My only problem is I don't have the original installation disk that came with my Macbook. Is there any way of intalling OS X without having the original cd? Purchasing/torrents etc.
Thanks
tarafından
You can go to an Apple Store and ask for the disks and they will give them to you for $20 or $30 last I checked. I think you can also call your nearest store and they will ship the disks to you.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 319
