Ana içeriğe geç
Rakuten Kobo tarafından Nisan 2024'te piyasaya sürülen Libra Colour eOkuyucunun onarım ve söküm bilgileri. N428 veya N428B model numaralarıyla tanımlanır.
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
yes that is a broken display, it would need to be replaced.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks a lot! wish me luck replacing the screen by myself hahaha
tarafından
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
tarafından
Yorum Ekle
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Kobo Libra Colour (N428) Ekran Değişimi and the Kobo Libra Renkli Ekran Değişimi guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Kobo Libra Colour N428 Ekran Görseli
Kılavuz
Zorluk:
Orta
45 minutes - 1 hour
Kobo Libra Colour N428B Screen Görseli
Kılavuz
Kobo Libra Colour (N428B) Screen Replacement
Zorluk:
Orta
1 - 2 hours
Puan 0
Yorum Ekle
Yanıtını ekle
ISDT sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 173
