Ana içeriğe geç
Open Amp Sensor error in GD compressor
Hi
I am working on Gardner Denver Compressor model Electra Saver.
I recently came across an error message Shutdown 'Open Amp Sensor'
This error message popped up within few minutes upon turning on. There is a light on the Compressor motor as seen in above pic, don't know what it means. The motor doesn't get hot.
After pressing Reset & then Constant run, the compressor runs, in most of the cases - all day. But sometimes it stops after running for few hours with above error message.
I tried to look thru the manual but couldn't find above Error message.
Any thoughts what this error is for & how to fix it?
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @rav60893
Here's the operating and service manual that may help.
Go to p.68 (78 of 82 pdf) in the manual, to see what to check when there's an Open Amp Sensor message.
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Thank you so much jayeff for sharing the appropriate manual. I was referring an incorrect one. I followed the Parameter on page 68. The manual says MONITOR SFA (looks like a typo). It's seems it should be 'MOTOR SFA; found on Page 25/82. Will work on it tomorrow .
tarafından Paylaş
Per the manual, CN-4 has 2 wires connected, probably the Current Sensor.
I will try to find the current transducer & CT.
Otherwise, is it ok to bypass it by simply disconnecting it and then thru Program -- Configuration Adjustment --- set MOTOR SFA to '0'?
tarafından Paylaş
@rav60893
I don't know, never worked on this type of compressor.
It's interesting to note that none of the wiring diagrams show anything connected to CN-4 whereas CN-3 has all the transducers/thermistors shown connected. (see p.52- p.54/82)
It does state: "If not installed, set the “MONITOR SFA” to zero amps in the configuration adjustments" so I suppose you could disconnect it and set Motor SFA to 0 and check .
Just be ready to turn it off quick, if necessary ;-)
I think that this may be the parts list but maybe check first and if it is , find the part number for the current transformer and transducer and search online for Gardner Denver (insert the wanted part number) to find a supplier - see p.50/58, p.52/58 & p.55/58 for the one that is applicable to your compressor. Usually part numbers are on the part itself if you wish to verify
tarafından Paylaş
Hi jayeff
Upon checking I noted there is a CT attached on the motor Contactor wiring. The CT wires are connected to Transducer & its output is connected to the Control board via CN-4 connector. Though, the wiring diagram doesn’t show anything connected on CN-4!
Assuming it’s 0-10Vdc output from transducer, with compressor running, should I expect between 0 - 10 Vdc OR 10Vdc?
tarafından Paylaş
@rav60893
See the Amp Sensor Failure section on p.21 (1/82) where it says that the amp sensor is an "optional extra". If there is none then it's functions are disabled.
Could be a varying voltage depending on what the compressor load is at the time but this is only a guess.
You could always measure it and check what it is with the compressor running
tarafından Paylaş
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Rav sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 257
