Ana içeriğe geç
Nintendo Switch, bir yerleştirme istasyonu aracılığıyla TV'de veya hareket halindeyken oynanabilen bir el tipi oyun konsoludur. 3 Mart 2017'de piyasaya sürülmüştür.
Getting the 2162-0002 error message when microSD card is inserted
If a microSD card is inserted I get the error message 2162-0002. With the microSD card slot empty everything works normally. I tried to switch the microSD card module, without success. The module works in a different switch and a working module give the same error when connected. This is a picture of the connector as I was not able to identify any faults myself (unless this spec in the middle on the left hand side has any meaning?).
Resim
Edit:
Was able to clean it with a toothbrush. Still getting the same error
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
Sounds like you've done quite a bit of testing. My first thought on this was definitely the connector and I'll be interested to see pictures. But just to make sure, have you also tried other microSD cards?
tarafından
Thanks for your feedback!
I tried several microSD cards and the same microSD card in a different switch. All seem to be working. Just not with that specific switch
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi!
I take a look at the pictures, the connector does not look good at the left side.
The pin where it need to connect there at left top and lower side look squished.
I'm afraid you need to replace that one. It won't be easy as soldering is required to fix it.
Do you have any soldering experience? If not, I would bring it to a local repair shop.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I have some soldering experience, but this would require micro-soldering, which is a very delicate work - So in that case I am not sure if I should try it and possibly cause more damage. Will have to really think it through..
tarafından
@spicyshaks23109 Soldering these sorts of connectors definitely takes some practice. Aside from the fact that it's so tiny, melting is a hazard because of the plastic bits. A hot air station (rather than just a soldering iron) would also make this much easier.
If it's something you're committed to fixing, you can practice first on some old cell phones. They might even be trickier because the board will be more densely populated with components than a Switch. But these type of FPC connectors are often found on cell phones.
tarafından
Yorum Ekle
Yanıtını ekle
SpicyShakshuka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 74
Her zaman: 364
