Ana içeriğe geç
PS4 kontrolcüsü, CUH-ZCT1 modeli. Kasım 2013'te Sony Computer Entertainment tarafından piyasaya sürülen, altı eksenli ve 3,7 V lityum iyon bataryalı bu kontrolcünün onarımı oldukça kolaydır. (NOT: Teardown rehberi bu model için DEĞİLDİR)
Am I soldering correctly?
This more of a general question I feel like I'm soldering at a too high temperature I keep damaging the mask around the vias sometimes stripping the mask around the vias revealing the copper I don't know if that compromises the connection or not at what temperature I should solder at? I currently solder at 400c I use both lead and lead free solder.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @christophe89153
Sounds like you're applying too much heat. Either that or you're applying it for too long.
Are you "tinning" the via first, before soldering it to the board?
Tinning means coating the part of the wire that you wish to solder with a thin layer of solder. Easiest way is to melt some solder on the tip of the soldering iron and then pass the part of the wire that you wish to solder through the molten blob of solder so that it gets a thin coating of solder. Then when you go to solder the wire to the board you only need a minimum amount of soldering time for it to solder onto the board.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
In my previous attempts I wasn't thinning the vias, but I was using flux. I have started to thin with low melt solder and got better results. I have 90w solder iron station and it can easily melts the low melt solder at 200c
tarafından
Yorum Ekle
Can you give a picture of what you are trying to solder? What type and wattage is the soldering iron you are using? 70W-90W will take care of most circuit board soldering. 320C -350C is probably better for small components. You are likely too hot.
Puan 0
2 Yorum:
I have a 90w solder station I'm soldering anything from batteries for cartridge games that use one to analog sticks for controllers
tarafından
@christophe89153 That should work with a good clean tip (small chisel type) . I think your temp was a bit high. Much higher than I ever use.
tarafından
Yorum Ekle
Yanıtını ekle
Christopher D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 138
