HP tarafından Aralık 2020'de piyasaya sürülen bir AMD iş dizüstü bilgisayarı olan HP EliteBook 845 G8 için onarım rehberleri, söküm ve sorun giderme bilgileri. 1W3K7AV model numarasıyla tanımlanır.
My screen came with the "Security Privacy" option on this HP 845 G8. The touch screen function is disabled. By design, I've never liked the viewing angles that it forces on the user. Now that I don't require the privacy screen nearly as much in my work, is it possible to change this screen out for a "standard" and/or "touch screen" version? This might be better asked of HP. Otherwise all is working just fine but just am curious to know what my options are.
I don't see a "HID - compliant touch screen" entry in Device manager. I don't believe the "Privacy Screen" function is integrated into a "touch screen" on this HP Notebook. This would then suggest that if I was to replace my screen there would have to be two different models for me to choose from.
Can anyone confirm this? What are the part #'s of each ?
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
3 Yorum
What's the "Product number" of the laptop as shown on the product information label on the bottom of the laptop?
Usually it is next to the model number on the label.
Also re the touch screen - in Device Manager check if there is an "Others" category as it may be there. If there's no Others category, click on View → Show hidden devices and check if it appears somewhere else in Device manager, where it shouldn't.
Toggling "Hidden Devices" did not reveal any device descriptions suggesting screens, display or touch anything. I do have a F2 key that allows me to toggle the privacy function on and off , but its not the same. The screen is NOT touch. and the screen resolution appears to be sub par vs a screen that is touch and minus the privacy function. This laptop was built custom by HP and was eventually shipped from China directly. 32g RAM 1T local drive, AMD Ryan 7 Pro, 5850U w/Radeon graphics. So again my ask is, Can I replace this non touch screen, with privacy add on with a touch screen with no privacy function in hopes we regain a higher grade of resolution, if possible. Again, tis might be a question for HP tech support but they may simply say,..."live with it" since its all functioning but NOT entirely to my liking.
I think I am going to learn "privacy screen add-on" disables touch screen functio
It can be done, yes - I did it on a 840 G6 when the SV panel was cracked and the cost was bordering in the price of a good computer without SV - SV also uses a proprietary display cable which cannot interchange with the 2k/4k 40-pin panels as it's wired to dim the panel, not run a high res LCD. You swap it like a standard display and the function dies as the key no longer triggers SV and defaults to a standard key. The cables aren't worth enough to bother recovering and selling them on. The housing is the same, the cable and panel are the whacky parts. Later machines like yours often use an ALS, which will probably work with a non SV panel but they never really shipped with it so you'd potentially need to swap the webcam out too. Get the 1920x1080 400 nit panel (M52488-001) and a standard iDP cable (30 pin).
The most cost effective way is to buy a used assembly, or a donor laptop. These use one shot adhesive, so it's cleaner to replace the LCD as a assembly here. My 8 G1a has SureView and I didn't check closely, the viewing angles were the hint I screwed up (and I did everything I can to avoid it, and got stuck with it - I didn't check because 32GB/512GB in a shortage for $566). If that unit has a panel crack or a TAB issue (even a bad cable) it is 100% being deleted and getting the 1600p 400 nit panel if this 1200p SV panel fails on me. The feature is garbage, HP does it to appease corporate America. It's optional for a reason.
3 Yorum:
Hey Nick. Thanks so much for your updates. You are a rebel and true hound in getting to the crux of my issue and needs. If and when I do replace this screen I might be better to trash the whole thing and buy new, but this notebook was rather expensive and need to get some use out of it before MS mandates a hardware upgrade to W12....lol.
So its a 30pin vs a 40pin connector tied to the DIM module that makes this a difficult dump of the SV (security screen) and increase a resolution a tad and remove the viewing limitations?
@nick... And of course I can always just hang additional extended monitors off this notebook and be a happy camper if I am at the home office and not in an airplane or cruise ship .
Just verifying that you tried turning off the privacy screen feature by pressing the designated action key on the keyboard (see image below for symbol on the key)?
If it has a touch screen you could try enabling it in Device Manager.
To get to Device Manager in Win10/Win11, press the Win key + x key (both together) and click on the Device Manager link on the menu box that opens.
When in Device Manager scroll down to Human Interface Devices → click on the > symbol to the left of the category, to expand the list → right clickon the HID - compliant touch screen entry → Enable device follow any prompts and then restart the laptop in the normal manner and once restarted check if the touchscreen works OK
There are no compatible LCD screens with a higher resolution capability or that have a touchscreen, for your particular laptop.
Go to p.21 (31 of 111 pdf) of the maintenance and service guide to see the HP part numbers for all the LCD panels that are compatible with the laptop.
They are all 14" FHD (Full High Definition - 1920 x 1080 max. resolution), UWVA (Ultra Wide Viewing Angle), non touchscreen LCD panels with a 30 pin cable connection.
Searching online it appears that the 1000 nits LCD panel is the only one with the Security Privacy screen option which it seems must be built into the panel.
To have touchscreen capability, you would need to have an LCD panel with integrated digitizer capability which requires having a 40 pin EDP cable connection on the motherboard or a display assembly, comprising an LCD panel and a separate digitizer panel having a 30 pin EDP cable connection and a separate digitizer cable connection on the motherboard i.e. EDP cable + digitizer cable to the display assembly. Looking at images of the motherboard used in your laptop, it only has a 30 pin EDP connection.
6 Yorum:
HP owner here - it's integrated :/. And yeah, it's a bad option to have unless you are in a high security environment. Best way to swap it out is a used assembly with the 400 nit 1080p panel, as the SV panel has an ALS which isn't needed with the 400 nit LCD. You also can't swap in a touch panel with the SV cable as it's for the driving layer. Even the 6 G1a doesn't have a touch option, the x360 series is 100% touch but most have soldered RAM, including the current one (but ships with 32GB).
Thank you Nick. Yea, I was fearing it might be highly integrated with very few options if I ever needed to replace the screen. 30 years in IT, working in raised floor data centers, and for large US based financial institutions working elbow to elbow with the Federal Reserves IT guys required me to restrict roaming eyes but now I don't require it to that degree and I have retired :-). Everything is working as stated, just don't like the degradation in screen and parallax which is by design and just want the full screen experience back without destroying the notebook. Going to search on "Nit" attributes and do some more research. Thanks again Nick and all. Any other links would be helpful!
The touch screen functionality is NOT a show stopper. Don't need it. Just want to remove the privacy option and replace the screen, if that is the only path and get back to better viewing and better resolution.
@tarzan1812 If I knew the my 8 G1a had SV I'd have run away from it :-(. The 32/256 spec was a nice find but ugh... SV sucks but I seen the RAM spec out of the box with a R5 230. And this was in the RAM crisis. Like I said, once this screen fails if it happens when it's worth repairing? No thanks, I'm getting rid of it. I put HP SV cables in a box of misc scrap with it on the lid and I know it's SV on those old pre G11/G1a machines because they were either 30-pin (iDP, not SV) or 40 pin (iDP, SV).
The dust is settling and yeah, we're seeing more machines with 32/256 or 32/512.
3 Yorum
Thanks for helping out.
Tarzan1812 tarafından Paylaş
@tarzan1812
jayeff tarafından Paylaş
HP EliteBook 845 G8
ProdID: 1W3K7AV
SN# 5CG2202FHL
Thanks for helping and sleuthing with me.
Chuck Weissmueller
