Check engine light on
PO171 PO174 error codes
Bu iyi bir soru mu?
The codes indicate a fuel too lean in Banks 1 & 2 problem.
This is usually either an airflow problem (too much air) or too little fuel getting to the engine.
Here's a video that shows how to check if the MAF (mass air flow) sensor is OK or not.
If it's a fuel problem it could be a clogged fuel filter or a fuel pump problem - low pressure
Hopefully a start to find out what's wrong.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 81
