Ana içeriğe geç
Atari Lynx, renkli LCD ekrana sahip ilk taşınabilir oyun konsoludur. Eylül 1989'da piyasaya sürülmüştür.
Can this be fixed?
So I bought a Atari lynx 2 from ebay and it there was no power even when I used batteries whoever owned the system tired to fix it used glue to attach the power jack. I tried to removed the glue carefully, but couldn't and I think that's a coil got ripped up among with solder mask will the system work without the coil if not can it be fixed?
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @christophe89153
Best option is to use the schematics to trace the power input path.
With batteries installed, check if there's 5V at the TP15 +5V test point as shown in the schematics and if not, start tracing it back to the battery terminals until you find it.
Once you've found it and fixed that problem then if it's still not working, you'll have to trace forward from the TP15 test point to find out why.
Hopefully a start.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Any chance you can highlight where I should scrape mask off? I did ask AI not sure if its correct. There was no power prior to this I was going to replace the zener diode and the mosfet
tarafından Paylaş
@christophe89153
Check at any of the components along the 5V power rail e.g., D9, D11, C36, D12, C40, C41, C42, R74, C44.
Whichever one is easiest to get to.
Always hard to know where to start i.e. the beginning of the path or at the end. If you start in the middle at least you know which way to go.
If there's no 5V at D9 check the battery connection terminals ;-)
tarafından Paylaş
Ok I'll see what I can do
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Christopher D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 38
Her zaman: 189
