Ana içeriğe geç
Nintendo Switch, bir yerleştirme istasyonu aracılığıyla TV'de veya hareket halindeyken oynanabilen bir el tipi oyun konsoludur. 3 Mart 2017'de piyasaya sürülmüştür.
Volume up Button not working
I'm trying to repair a Nintendo Switch where the volume up (+) button is not responding. Volume down (-) and Power are working fine.
I allready replaced the flex cable.
Same behaviour. Vol + not working, Vol - and Power are working.
Any idea, what could cause this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
Hi!
Does it click in well? Do you feel the click? Did you also replaced the rubbers?
If this is the case, you might want to check the connector on the motherboard where it connects to.
If this one is OK, I think it it's the motherboard having issues here.
Did you tried headphones, do they work?
tarafından Paylaş
@dan0 As I said, I already replaced the Flex cable. But still the same behavior. Tried to click directly on the flex. Connector looks good.
After a bit of googling I am quite sure it is a resistor near the connector.
tarafından Paylaş
Hi!
Sorry, I meant if you also feel the click on the replacement part. I'm pretty sure it is something on the motherboard. Replacing the resistor would be the next thing to do.
tarafından Paylaş
@dan0 My replacement part is working well. Do you know which resistor exacly is for the Vol+ Button?
tarafından Paylaş
Not 100% sure no. Maybe you can check this out: https://gbatemp.net/threads/volume-butto...
There is not a lot to find about it, except that more people are having the exact same issue as you...
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Thanks @dan0
Your gbatemp link was exactly what I was looking for.
For others as reference:
Resim
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi @nintendoc,
That's it :)! We found it.
This is actually really helpful.
That one need to be replaced for sure.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Nintendoc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 59
Her zaman: 175
