Ana içeriğe geç
Su soğutmalı ilk nesil Porsche 911 modelleri olan 996 serisi için onarım rehberleri ve destek.
Stop light not working
Right stop light not working, my 996 has aftermarket LED tail lights, I replaced both unit door new ones and the problem continues..
All other lights work fine (turn signals, hazards, reverse, night lights)
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thank you! I checked for 12v on tje 4 pin at the light with the brake pedal pressed without any luck… will have to trace that 13 connection… doesn’t look like a fun task, specially with no electric experience…
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @diegoestra71869
Check if there's 12V DC on pin 4 of the connector that the right tail light assembly cable plugs into, when the brake pedal is operated.
If there isn't and since the left side brake light is working, there may be a wiring problem between pin 4 on the connector and the multiple wiring connection point # 13.
Unfortunately I don't know where that is located. You may have to trace the harness wiring back from the right side (or the left side) tail light assembly.
Here's an image of the relevant part of the wiring diagram that may help.
Resim
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Diego Estrada sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 119
