Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
Bu iyi bir soru mu?
3 Yorum
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
honakrisi tarafından Paylaş
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
sascha bauló martínez tarafından Paylaş
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
koppie007 tarafından Paylaş
