Ana içeriğe geç
Bu ünite, ChiliPad yatak pedinin içinden dolaştırdığı suyu soğutur veya ısıtır. Model: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit ChiliTechnology ChiliCube Teardown / söküm guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
Resim
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thanks for the info. I will let you know how i progress.
tarafından Paylaş
Fuse is good. So still looking.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Andrew Lovell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 123
