Ana içeriğe geç
Lehimleme, iki metal parçasını aralarına dolgu metali eriterek birleştirme yöntemidir. Birçok lehimleme türü vardır ancak bu makale, size temel elektriksel lehimlemeyi öğretmek için hazırlanmıştır.
Attach camera to microscope
I am using an Amscope microscope for soldering. I would like to attach a Nikon Z mount camera to it. What solutions have worked for folks? Thank you!
Update (09/03/26)
The microscope is an Amscope SM-4T
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You'll need a 30mm tube that fits into the microscope camera port with the needed mount. I got my microscope with the video camera with a C mount.. Contact Amscope for the needed tube or try Edmond Scientific
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Thank you Dan. I will have a look at Edmond. There is also a place called Microscope World that may have a solution. The ID of the port is 23mm with an OD of 25mm. You have headed me in the right direction and I will make some phone calls.
tarafından Paylaş
@b53evans - Why are you using the eyepiece not the third camera port? I haven't seen the need to use the eyepiece when you have a binocular microscope. Doesn't this model offer it? The lookup I did implied it did.
tarafından Paylaş
DanJ, you are correct. The measurements above are the camera port. I believe I have found a solution that will attach to the Z8 lens attachment ring and then drop into the camera port (https://www.microscopeworld.com/microsco...). I will order it and update this thread. Thanks for the push toward a solution.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
b53evans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 90
