Battery replacement for XPS 9520
Hello. I bought a refurbished Dell Xps 9520 and I want to replace the battery. Few weeks ago I replaced the cpu and gpu thermal paste and tool a picture of the battery.
I found the battery here, on ifixit.com but when I check the compatibility It says: This does not fit Dell XPS 15 9520.
So, does it fit? Or not...
Thanks
Update (09/18/26)
Here
Bu iyi bir soru mu?
Hi! I opened a moderation vote to move this question to the iFixit Meta forum, where this question is a little better suited as this is more of a customer support question. If you do not get an answer within a few days I would suggest contacting the iFixit support directly to guarantee an answer which you can do at https://www.ifixit.com/Support
Hope this issue is resolved soon,
Cheers
MeekVixen tarafından
Hi @liviurabac
Where does it state on the page you linked that it is not compatible?
I can't find any mention of the model number you listed on the page and when using the Compatibility search box on the page to look for your model it just says no results, which usually means that it can't find it and not that it isn't compatible.
You can check if it physically fits by looking at the image of the battery on the page you linked and compare the position and number of screw mounts on the battery against what the battery in your laptop has.
jayeff tarafından
This question has been migrated to https://meta.ifixit.com/Answers/View/229....
iRobot tarafından
