Ana içeriğe geç
Toyota Camry'nin XV20 serisi, Toyota'nın 6. nesil Camry sedan modelidir.
Code P0758 Camry 1998 V6
Hi everyone! I have a 1998 Toyota Camry V6 with Automatic transmission. I’ve got a Check Engine light with code P0758 wich means Solenoid B Electrical. The car is originally from California and drove 41 000 miles there before it got imported to Norway in 2007. It has only drove 42 000 miles since then here in Norway, so I find it difficult to see a problem with the wirings. Does anyone have experienced kind of the same problem and help me out?
Camry Owner.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @vebjoernbek4505
The car is approx. 28 years old so a wiring problem is not out of the question. The wiring could fail for any number of reasons e.g. corrosion, wiring fatigue etc.
Here's the P0758 diagnosis and repair procedure from the service manual, that may help.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hi! I did som research and found out that the S2 terminal in the transaxle connector is OL, and the manual then says «replace the transaxle sub-harness as needed». I can’t find the part number for this specific part (sub-harness). Can you help me out? I’m starting to realize that this sounds expensive if I have to use specialists…
tarafından Paylaş
@vebbe11
Try this website and see if you can find it.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Vebjørn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 54
Her zaman: 54
