Ana içeriğe geç
Indesit bulaşık makineleri için tamir bilgileri.
Not spraying during normal cycle.
Whirlpool WDF560SAFM2.
New circulation pump
Filter Clear, Spray arms clear, Manifold clear, pump inlet/return clear.
Ample water when running
No Error Codes F- E-
Works perfectly during a maintenance cycle but water only dribbles out of both sprayers on any normal cycle
Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Hi @kentrhodes44149
Do both arms rotate albeit slowly?
If only one moves it could be a faulty diverter or diverter disc.
Have you tried just a water only wash i.e. no detergent or rinse aid to check if the arms rotate normally i.e. strong water pressure out of arms?
If they do it could be a problem with air getting into the pump from the dispensers
tarafından Paylaş
It might be the rotating diffuser plate. It sits firmly on the motor axis and doesnt look worn at all but i will find it askew when I open it up to look at it. It anything supposed to hold it down? There arent any clips or catches that seem to hold it in place
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @kentrhodes44149
There's a small slot located in the hub of the diffuser that lines up with a spline on the end of the shaft that should hold it in position.
Check that the diffuser stays in position and can't move unless the shaft moves.
Here's an image of the diffuser used in your model. The arrow is showing where the slot it.
Resim
(click on image)
Note: Most parts suppliers call it a diffuser, but the supplier that I copied the image from calls it a diverter plate (and also a suction plate) but the part number shown is the same one shown by all suppliers that I checked.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
The diffuser plate groove fits tightly over the spline on the shaft when its seated fully but the water pushes the plate up far enough that the spline slips out of the groove and allows it to spin freely. I've ordered a new one. The groove on my original one does not extended the full length of the shoulder but i don't see any obvious wear. Maybe its just worn so smooth that its looks like new.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Kent Rhodes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 43
Her zaman: 43
