999 is flashing
What does it mean when the 999 is flashing?
Bu iyi bir soru mu?
Silvia - I think you need to reset your camera's counter. Give that a try.
Bu yanıt yardımcı oldu mu?
The blinking is actually a normal function during the write access to the card.
The 999 will keep flashing even when I turned the camera off, I had to take the battery out to get it to stop. When it was flashing it would not let open menu or look through images; the big screen would just stay black. Once I did take the batteries out and in it would work, but only for a little while till it started doing it again. Sos??
Did it save the images you already had on the card.?? I'm having the same issue!!
my camera is now permanently in this condition. Cant turn off the camera and all the display items that can flash, flash. tried everything to no avail. Do I have to send it back to Canon? its not easy for me because there is no service centre within 1000km
That's what my camera is doing after getting wet. Any solutions so far (besides sending the cam to Canon)?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 6,414
3 Yorum
How much room do you have left on your card? Check with a CF card reader the condition of your card and the images
oldturkey03 tarafından
Thks, oldturkey03.
I think I know. Before this 999 issue, I was using a defective CF card, which I replaced with a new card. The previous card never showed the flashing 999, so it was unfamiliar to me. When shooting with my new card, however, I do see it flashing, which seems to happen while the camera is busy saving my last image. After the busy light goes out, the flashing 999 stops.
I can only assume that a flashing 999 simply means it's busy saving an image. There don't seem to be any other problems or issues now.
Sylvia
Sylvia tarafından
Sylvia, that is what it is doing. The 999 is obviously the storage capacity left on your card, as the image is being saved, and the card being accessed that number flashes. Best of luck to you.
