Ana içeriğe geç
2007 Honda CR-V Brake Light Replacement
Dillon Laney
Dillon Laney ve 2 diğer katkıda bulunanlar
En son May 24, 2023 tarihinde güncellendi
5 - 10 dakika
Kolay
Owning a vehicle should not come with unmanageable maintenance requirements. Therefore, this guide is designed to help assist owners of the 2007 Honda CRV replace their broken brake lights. Although there are other manuals and guides for fixing this light, the majority of them are in video form. For auditory learners and those with little experience fixing cars the assumed car proficiency for the viewer within these videos can be daunting. Additionally, most of these videos show no distinction between the particular CR-V’s model and production year, and they do not reference a specific rear light part.
We have created our written guide to help clarify this procedure, step by step, focusing uniquely on fixing the bulb from the brake light for a novice audience.
Before beginning this guide, power off the ignition, place the car in park, and engage the parking brake.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement, Brake Light: adım 1, 3 resimden 3.
    • Grab the handle in the middle of the trunk.
    • Use the handle to pull the trunk open.
  2. 2007 Honda CR-V Brake Light Replacement: adım 2, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the top and bottom screws.
  3. 2007 Honda CR-V Brake Light Replacement: adım 3, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 3, 2 resimden 2.
    • Pull back the tail light cover.
    • Hold it up; there are cords connected to the car inside.
  4. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement: adım 4, 3 resimden 3.
    • Untwist the faulty bulb counter-clockwise.
    • Pull the bulb out of the socket.
  5. 2007 Honda CR-V Brake Light Replacement: adım 5, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 5, 2 resimden 2.
    • Disconnect the bulb from the cord by popping it off.
  6. 2007 Honda CR-V Brake Light Replacement: adım 6, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 6, 2 resimden 2.
    • Pop in the Sylvania LongLife Mini Bulb 7443LL.
  7. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 2. 2007 Honda CR-V Brake Light Replacement: adım 7, 3 resimden 3.
    • Insert the bulb into the socket.
    • Twist the bulb in clockwise.
  8. 2007 Honda CR-V Brake Light Replacement: adım 8, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 8, 2 resimden 2.
    • Set the tail light cover back to the default position over the screw holes.
  9. 2007 Honda CR-V Brake Light Replacement: adım 9, 2 resimden 1. 2007 Honda CR-V Brake Light Replacement: adım 9, 2 resimden 2.
    • Use a Phillips #00 screwdriver to screw in the top and bottom screws.
Bitiş Çizgisi
Dillon Laney
169 İtibar
1 Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 72
Her zaman: 1,989
