Ana içeriğe geç
2011 Scion Tc Blower Motor Replacement
Jose Ruvalcaba
Jose Ruvalcaba ve 2 diğer katkıda bulunanlar
En son June 17, 2022 tarihinde güncellendi
8 dakika
Orta
This guide explains how to replace a 2011 Scion Tc 2011 blower motor. If your vehicle's HVAC doesn’t blow air at all, then it can be your blower motor. The blower motor turns the blower fan, which sends fresh air to your vehicle.
This replacement is fairly straightforward. This repair is needed for every 2011 Scion Tc, because blower motor plays an important role to keep drivers cool or warm. It's a crucial part of the heating and cooling systems in a 2011 Scion Tc.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. 2011 Scion Tc Blower Motor Replacement, Blower Motor: adım 1, 1 resimden 1.
    • Locate your blower motor. Your blower motor should be below the glovebox.
  2. 2011 Scion Tc Blower Motor Replacement: adım 2, 1 resimden 1.
    • Remove the three 2 mm screws that secure the blower motor.
  3. 2011 Scion Tc Blower Motor Replacement: adım 3, 1 resimden 1.
    • Remove the two 1 mm Phillips #0 screws that secure the blower motor wiring harness.
  4. 2011 Scion Tc Blower Motor Replacement: adım 4, 2 resimden 1. 2011 Scion Tc Blower Motor Replacement: adım 4, 2 resimden 2.
    • Disconnect the sensor that is connect to the blower motor.
    • The sensor should have a click and carefully remove it upwards.
  5. 2011 Scion Tc Blower Motor Replacement: adım 5, 2 resimden 1. 2011 Scion Tc Blower Motor Replacement: adım 5, 2 resimden 2.
    • Put the new blower motor in place, and secure it with the three 2 mm Phillips #0 screws.
  6. 2011 Scion Tc Blower Motor Replacement: adım 6, 1 resimden 1.
    • Tighten the two 1 mm screws to the wiring harness.
  7. 2011 Scion Tc Blower Motor Replacement: adım 7, 1 resimden 1.
    • Congratulations, you have successfully replaced your blower motor!
    • Once all the screws are tightened, just make sure to turn on your air to see if your blower motor works!
Sonuç
Jose Ruvalcaba
145 İtibar
1 Kılavuz yazıldı
Bir Yorum
Is the blower motor inside of the car under the glovebox? Do I need to replace the glovebox to get to the blower motor?
Christopher Sean Harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 60
Her zaman: 1,500
