Ana içeriğe geç
4. Installing Klipper on SKR3 EZ
    • Download and extract the latest version of Mainsail from their Github
    • Open the Raspberry Pi Imager
    • Select Operating System > Use custom > Select the Mainsail OS you downloaded.
    • Select Storage > Select your SD/USB.
    • Bring up the Advanced Settings menu by pressing CTRL+SHIFT+X
    • Here you can setup your WiFi, locale, enable SSH and numerous other options.
    • Write > Yes to confirm
    • After imaging is complete the SD/USB is automatically ejected. Insert it into the RPI.
  1. 4. Installing Klipper on SKR3 EZ: adım 2, 3 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 2, 3 resimden 2. 4. Installing Klipper on SKR3 EZ: adım 2, 3 resimden 3.
    • Connect your Raspberry Pi to the SKR3 EZ by USB or UART cable. I used a UART cable so that is what I will be showing but I'll try to explain how to setup USB as well.
    • UART wiring
    • PA10 > GPIO15
    • PA9 > GPIO14
    • GND > GND
    • For USB ONLY connect a USB cable from the SKR3 EZ to the RPI and place a jumper on VUSB
    • Make sure the double throw switch is in the up position
    • Connect the RPI to it's 5v power supply and power it on. Do not power on the the 24v PSU
  2. 4. Installing Klipper on SKR3 EZ: adım 3, 2 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 3, 2 resimden 2.
    • Verify the RPI is connected to your network. Open command prompt and run
    • ping mainsailos.local
    • You should see it return successful pings
    • Open a web browser and go to
    • mainsail.local
    • On the machine tab you can see the IP address of your RPI next to "wlan0"
    • I use Remote Terminal, but using your favorite SSH client login to your RPI with the default credentials
  3. 4. Installing Klipper on SKR3 EZ: adım 4, 3 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 4, 3 resimden 2. 4. Installing Klipper on SKR3 EZ: adım 4, 3 resimden 3.
    • Set your locale
    • sudo raspi-config
    • Set your region preferences for L1-L4
    • Reboot your RPI when finished
  4. 4. Installing Klipper on SKR3 EZ: adım 5, 1 resimden 1.
    • SSH back into your RPI and run
    • sudo apt-get update
    • sudo apt-get upgrade -y
    • Because I used a brand new image (released the day before) there was nothing to update. If yours installs updates make sure you restart the pi
  5. 4. Installing Klipper on SKR3 EZ: adım 6, 1 resimden 1.
    • SSH into your pi and run
    • cd ~/klipper
    • make menuconfig
    • Set the following parameters
    • Enable extra low-level configuration options
    • Micro-controller Architecture (STMicroelectronics STM32) --->
    • Processor model (STM32H743) --->
    • Bootloader offset (128KiB bootloader (SKR SE BX v2.0)) --->
  6. 4. Installing Klipper on SKR3 EZ: adım 7, 3 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 7, 3 resimden 2. 4. Installing Klipper on SKR3 EZ: adım 7, 3 resimden 3.
    • Continued
    • Clock Reference (25 MHz crystal) --->
    • 3 wire cable connected from TFT to RPI GPIO
    • Communication interface (USART1 (on PA10/PA9)) --->
    • USB Cable
    • Communication interface (USB (on PA11/PA12)) --->
    • Press ESC key
    • Y to save configuration
  7. 4. Installing Klipper on SKR3 EZ, ***For USB connected board only***: adım 8, 2 resimden 1. 4. Installing Klipper on SKR3 EZ, ***For USB connected board only***: adım 8, 2 resimden 2.
    • Press and hold the BOOT and RESET buttons.
    • Release the RESET button first, than release BOOT. This will put the board in DFU mode.
    • Get the boards ID number by running
    • lsusb
  8. 4. Installing Klipper on SKR3 EZ, For UART and USB Connected Boards: adım 9, 2 resimden 1. 4. Installing Klipper on SKR3 EZ, For UART and USB Connected Boards: adım 9, 2 resimden 2.
    • Compile the firmware by running
    • Make
    • The SKR3 doesn't have a bootloader so you cannot flash it from the RPI. You'll need to use the SD method.
    • Open WINSCP
    • Navigate to /klipper/out/
    • Copy klipper.bin to your PC and rename it to firmware.bin
    • Copy firmware.bin to a SD. I used a 128mb one I had laying around
    • Holding the RESET button on the SKR3 EZ, insert the SD card into the SKR3 EZ.
  9. 4. Installing Klipper on SKR3 EZ: adım 10, 2 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 10, 2 resimden 2.
    • Release the reset button and the firmware will update. When the status LED goes out the firmware update is complete.
    • Remove the SD card and press the RESET button.
    • FOR USB CONNECTED ONLY
    • You need to get the boards ID. Run
    • ls /dev/serial/by-id/
    • Reboot the RPI
  10. 4. Installing Klipper on SKR3 EZ: adım 11, 1 resimden 1.
    • Power on the RPI and SSH into it.
    • Run
    • cd ~/klipper
    • sudo cp "./scripts/klipper-mcu-start.sh" /etc/init.d/klipper_mcu
    • sudo update-rc.d klipper_mcu defaults
    • sudo service klipper stop
    • make clean
    • make
  11. 4. Installing Klipper on SKR3 EZ: adım 12, 2 resimden 1. 4. Installing Klipper on SKR3 EZ: adım 12, 2 resimden 2.
    • Continued
    • make menuconfig
    • Micro-Controller Architecture > Linux Process. Press esc than Y
    • make flash
    • sudo service klipper start
    • Verify klipper_host_mcu is in the tmp directory with ls /tmp/*
    • Add the pi to the TTY group
    • sudo usermod -a -G tty pi
    • Once complete go to Step #** Canbus
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
David Husolo
9.162 İtibar
33 adet Kılavuz yazıldı
5 Yorum
is it suitable for skr 3 but NOT EZ version?
Vlad Vovk - Yanıt
that saved my life, thx
Balint V - Yanıt
is it different for a btt pi4b with cb1 emmc 32g
Dustin brooks - Yanıt
Thank you. I have it running with a BTT Pi (power 24V) and using USB with the SKE3 EZ.
Step 8 (Get the boards ID number by running) is only needed as check if things work.
/dev/serial was not created due to a faulty Debian script but can be solved by updating and upgrading "sudo apt -y update && sudo apt -y upgrade".
Zekitez - Yanıt
"The SKR3 doesn't have a bootloader so you cannot flash it from the RPI"
SKR3 has a 128 KB bootloader. Yet you can't flash it from the Pi.
Arty Chow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 64
Son 30 gün: 272
Her zaman: 9,526
