Ana içeriğe geç
8BitDo Pro 2 D-Pad Replacement
Neye ihtiyacın var
  1. 8BitDo Pro 2 D-Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the 8BitDo Pro 2 controller so that the back side is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. 8BitDo Pro 2 D-Pad Replacement: adım 2, 1 resimden 1.
    • Slide the battery cover off to remove it and expose the battery.
    FixBot'a Sor
    Yorum Ekle
  3. 8BitDo Pro 2 D-Pad Replacement: adım 3, 1 resimden 1.
    • Use your hands to remove the battery pack from the controller.
    • Do not bend or puncture the battery pack, this can be hazardous.
    FixBot'a Sor
    Yorum Ekle
  4. 8BitDo Pro 2 D-Pad Replacement, Controller: adım 4, 1 resimden 1.
    • Using the iFixit blunt tweezers, peel back the top two corners of the sticker located inside the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  5. 8BitDo Pro 2 D-Pad Replacement: adım 5, 1 resimden 1.
    • Use a T6 Torx screwdriver to remove the four 5.0 mm screws from the back of the controller.
    FixBot'a Sor
    Yorum Ekle
  6. 8BitDo Pro 2 D-Pad Replacement: adım 6, 3 resimden 1. 8BitDo Pro 2 D-Pad Replacement: adım 6, 3 resimden 2. 8BitDo Pro 2 D-Pad Replacement: adım 6, 3 resimden 3.
    • Insert the iFixit pick into the seam along the edge of the controller and slide it around to release the clips holding it together.
    • Leave opening picks in the space to keep the top and bottom case from reattaching.
    • Use an iFixit tool to carefully pry around the edges of the controller.
    • Once loosened, gently separate the top and bottom of the controller.
    • Do not separate the top and bottom sections, as they are still connected by a ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. 8BitDo Pro 2 D-Pad Replacement: adım 7, 2 resimden 1. 8BitDo Pro 2 D-Pad Replacement: adım 7, 2 resimden 2.
    • Use a spudger to gently push up on alternating sides of the black plastic tab until it clicks up into its unlocked position.
    • Don't push the tab too hard or too far, otherwise it may come completely off the connector.
    • Use tweezers to gently pull the cable out of its socket.
    • The cable should be able to slide in and out of the socket with little to no force. If you feel resistance, the tab may not be fully unlocked.
    • During reassembly, insert the cable into its socket and use the flat end of a spudger to push the tab down into its locked position.
    • Separate the top and bottom casing of the controller.
    • If you feel resistance, check for any cables still connecting the two halves and avoid forcing them apart.
    FixBot'a Sor
    Yorum Ekle
  8. 8BitDo Pro 2 D-Pad Replacement, D-Pad: adım 8, 3 resimden 1. 8BitDo Pro 2 D-Pad Replacement, D-Pad: adım 8, 3 resimden 2. 8BitDo Pro 2 D-Pad Replacement, D-Pad: adım 8, 3 resimden 3.
    • Remove the six, 10.0 mm Phillips #00 screws along the edge of the main board.
    • Remove the 5.0 mm Phillips #00 screw towards the center of the board.
    • Pull the main board from the top case to remove it.
    FixBot'a Sor
    Yorum Ekle
  9. 8BitDo Pro 2 D-Pad Replacement: adım 9, 1 resimden 1.
    • Gently pull the conductive rubber cover off the D-pad.
    FixBot'a Sor
    Yorum Ekle
  10. 8BitDo Pro 2 D-Pad Replacement: adım 10, 1 resimden 1.
    • Push the D-Pad out of the top case to remove it.
    • You may heard a clicking sound as the D-Pad is removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Paige Lucas
563 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Rioux Spring 2026 UMass Dartmouth, Team 5-3, Rioux Spring 2026 üyesi
UMASSD-RIOUX-S26S5G3
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 60
Her zaman: 89
