Ana içeriğe geç
8BitDo Ultimate Wireless Joystick Module Replacement
Neye ihtiyacın var
  1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: adım 1, 2 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: adım 1, 2 resimden 2.
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    FixBot'a Sor
    Yorum Ekle
  2. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 2, 2 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 2, 2 resimden 2.
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    FixBot'a Sor
    Yorum Ekle
  3. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 3, 3 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 3, 3 resimden 2. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 3, 3 resimden 3.
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  4. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 4, 3 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 4, 3 resimden 2. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 4, 3 resimden 3.
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  5. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: adım 5, 1 resimden 1.
    • Grip each analog stick cap firmly and pull straight up to remove them.
    FixBot'a Sor
    Yorum Ekle
  6. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 6, 2 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 6, 2 resimden 2.
    • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
    FixBot'a Sor
    Yorum Ekle
  7. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 7, 2 resimden 1. 8BitDo Ultimate Wireless Joystick Module Replacement: adım 7, 2 resimden 2.
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
473 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 üyesi
UMASSD-BISWOKARMA-S26S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 163
