Giriş
Do you need to replace the joystick module on your 8BitDo Ultimate Wireless? If so, this guide will show you how to correctly and safely do so!
With that said, please make sure to check our Troubleshooting Guides first. Often times, there is no need to go as far as replacing the joystick module entirely.
Before beginning, turn off the controller and ensure it will not accidentally reconnect during the repair.
This guide requires soldering. Be sure that you have all of the necessary equipment and knowledge before beginning.
Neye ihtiyacın var
Insert an opening pick into the seam between the left controller grip and main controller body.
Pry the grip off.
Repeat for the right grip.
Grip each analog stick cap firmly and pull straight up to remove them.
Turn to the backside of the circuit board for clear access to the solder joints.
Desolder all of the outlined solder joints.
Refer to the following solder guide if necessary: How To Solder and Desolder Connections
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
