Ana içeriğe geç
ANKER SoundCore Battery/Battery Wire Replacement
Neye ihtiyacın var
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: adım 1, 3 resimden 1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: adım 1, 3 resimden 2. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: adım 1, 3 resimden 3.
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
    FixBot'a Sor
    Yorum Ekle
  2. ANKER SoundCore Battery/Battery Wire Replacement: adım 2, 1 resimden 1.
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
    FixBot'a Sor
    Yorum Ekle
  3. ANKER SoundCore Battery/Battery Wire Replacement: adım 3, 3 resimden 1. ANKER SoundCore Battery/Battery Wire Replacement: adım 3, 3 resimden 2. ANKER SoundCore Battery/Battery Wire Replacement: adım 3, 3 resimden 3.
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
    FixBot'a Sor
    Yorum Ekle
  4. ANKER SoundCore Battery/Battery Wire Replacement: adım 4, 3 resimden 1. ANKER SoundCore Battery/Battery Wire Replacement: adım 4, 3 resimden 2. ANKER SoundCore Battery/Battery Wire Replacement: adım 4, 3 resimden 3.
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
    FixBot'a Sor
    Yorum Ekle
  5. ANKER SoundCore Battery/Battery Wire Replacement: adım 5, 1 resimden 1.
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Lucas Sandsor
313 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G1, Regan Winter 2020 Cal Poly, Team S22-G1, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G1
5 Üyeler
7 adet Kılavuz yazıldı
6Kılavuz Yorumları
If a bt speaker battery died,the unit can't power up by cable?
limz555 - Yanıt Paylaş
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - Yanıt Paylaş
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - Yanıt Paylaş
Where do I get the new battery in India?
Raghubir Roy L - Yanıt Paylaş
What are the specs on the battery, so I can double-check compatibility for a replacement?
Andy Mattson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 101
Son 30 gün: 417
Her zaman: 32,156
