Giriş
If your battery is worn or defective, this guide will show you how to replace your battery. The battery is located internally in the laptop and requires removal of the keyboard module for access.
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 farklı kişi bu kılavuzu tamamladı.
2 Comments
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
