Ana içeriğe geç
ASUS D550MA-DS01 Battery Replacement
Neye ihtiyacın var
  1. ASUS D550MA-DS01 Battery Replacement, Keyboard Module: adım 1, 2 resimden 1. ASUS D550MA-DS01 Battery Replacement, Keyboard Module: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
  2. ASUS D550MA-DS01 Battery Replacement: adım 2, 1 resimden 1.
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 Battery Replacement: adım 3, 2 resimden 1. ASUS D550MA-DS01 Battery Replacement: adım 3, 2 resimden 2.
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    I need assistance. When I opened the cover, exposing the keyboard and main board I pulled the 3 blue and white data cables from the main board. How can I repair this? Someone please help!!!!!!
    Angela Rene'e Dortch - Yanıt
  4. ASUS D550MA-DS01 Battery Replacement: adım 4, 1 resimden 1.
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  5. ASUS D550MA-DS01 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the fully disconnected keyboard module from the laptop.
    No need to remove the keyboard. The ribbons are plenty long to give slack and allow access.
    hellcat - Yanıt
    Good overall, thank you!
    hellcat - Yanıt
  6. ASUS D550MA-DS01 Battery Replacement, Battery: adım 6, 2 resimden 1. ASUS D550MA-DS01 Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
    • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
  7. ASUS D550MA-DS01 Battery Replacement: adım 7, 2 resimden 1. ASUS D550MA-DS01 Battery Replacement: adım 7, 2 resimden 2.
    • Lift the battery out and remove it:
    • The battery is connected to the motherboard on the left side.
    • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
    • Pull straight up to lift the battery out of its place.
    • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 farklı kişi bu kılavuzu tamamladı.
Richard Johnson
704 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Fall 2015 IUPUI, Team 1-2, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S1G2
3 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Robert Beasley - Yanıt
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
MIGUEL MORENO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 4,877
